12royal
Post by 12royal » Fri Apr 05, 2019 9:33 am
Mot test today, passed with frying colours.✅
5 x
8drfc
Post by 8drfc » Sun Apr 14, 2019 10:08 am
Took it to see Mr MOT, had to do all the work for him as he can’t get it on/off the stand or start it.
DIY MOT”s are great,
Passes no problems, quick blast round Wiltshire then home.....I’m still worried, it keeps starting no problem.
Just noticed a bit of a leak from the sump, need to check it out.
Anyone else in Wiltshire?
rustybike
Post by rustybike » Sun Apr 14, 2019 1:56 pm
put an engine in it
landy man
Post by landy man » Thu Apr 18, 2019 6:08 pm
Rode my MT to work this morning,got home a decided it was time to fit my rebored barrel and piston.
Should have up and running tomorrow.
1985 MT500 Green...07 KE 57.
1972 series 3 Lightweight,GS,Green.Waddington strike command
1978 Series 3 Lightweight,GS,light stone.Black watch 1st battalion.
1957 Triumph 6T Thunderbird
1959 Triumph 5TA speed twin.
1964 series 2A landy.
Post by twmtomos1 » Fri Apr 19, 2019 7:08 am
let us know how you get on,thanks
Post by lardmarc » Fri Apr 19, 2019 9:18 am
Walked past it.
landy man
Post by landy man » Fri Apr 19, 2019 12:05 pm
The bike is back together,started 2nd kick.I refitted a Champion spark plug as I find these plugs more reliable than the NGK ones.
About 6 hours work to complete the change over.
I'm going to run it up a few times then remove the tank,check for oil leaks and give the engine a de-grease with Jizer...
Happy days!
Post by twmtomos1 » Fri Apr 19, 2019 6:15 pm
well done let us know how it goes
landy man
Post by landy man » Tue Apr 23, 2019 9:30 pm
Took the MT out for a good test ride yesterday evening,rode up chalk pit lane to the top of the Trundle hill by Goodwood race coarse,bike went well,no difference really from how the engine was prior to the barrel/piston change,possibly a little quieter but nothing else.
Was wanting to ride the MT today but looked at it this morning and I've got a bloody puncture!!!
Two new tubes coming tomorrow,sods law is I have 3 new front tubes but no rears!!! :cry:
landy man
Post by landy man » Wed Apr 24, 2019 4:55 pm
Fitted my new rear tube tonight,thought I'd take a closer look at the knackered punctured tube,.
Blew the thing up so as a good photo was possible.
You can see that the cause of the puncture was from the tyre securing rubber clamp!
I'm now wondering if it's worth having it fitted for the kind of use I do on the bike.
I will remove it if I get another puncture in the same place,add or remove wheel balance weights if I need to.
My Norton Commando and several bonnivilles never had them.
What do you think?
