1ST GEAR
Para1
1ST GEAR
Post by Para1 » Mon Oct 21, 2019 8:07 pm
We've all had it, anyone got a solution to find or resolve finding the allusive 1st gear on an MT350, someone sorted before but I can't find the thread ;)
Re: 1ST GEAR
Post by Wirralman » Mon Oct 21, 2019 8:38 pm
Is your gear lever bent ? If you've been off roading it's easy to bend then. Remove lever and straighten in a vice
Is clutch cable adjusted correctly
Tickover too slow?
If the bike is moving, you should be able to select 1st easily
Do you have a clutch adjusting tool ( If not drop me a pm) an incorrectly adjusted clutch doesn't help
Is clutch lever bush worn ?
With fresh oil, the clutch release may be easier
The last thing would be to take off the side engine cover, strip clutch ( clutch holding tool required), clean plates and measure stack height, file out ridges in basket, renew clutch springs and plates if necessary
If you do all of the above and it still isn't right , ask again
If you don't want to do the work yourself, take your bike to Sportax
Re: 1ST GEAR
Post by Minter » Tue Oct 22, 2019 1:18 pm
Good advice from Eric as always..
Strip and check the clutch and reface the clutch basket..
We do this job now whilst customers wait..
Hope that helps
Para1
Re: 1ST GEAR
Post by Para1 » Tue Oct 22, 2019 3:40 pm
Thanks for the advice ;)
Para1
Re: 1ST GEAR
Post by Para1 » Tue Oct 22, 2019 3:41 pm
Minter,
Meant to ask whats the charge for that please?
Para1
Re: 1ST GEAR
Post by Para1 » Tue Oct 22, 2019 3:52 pm
Wirralman,
None of the aforemenioned you listed seem to aflict my bike so I suspect it might need some TLC from someone who has rectified the issue of seeking the 1st gear before like Minter, inside the box.
Re: 1ST GEAR
Post by Wirralman » Tue Oct 22, 2019 4:29 pm
Para1 wrote: ↑
Wirralman,
Unusual but if none of the above sorts it, then Sportax is the ONLY outfit I would trust. Good luck
