Replacement speedo MT350
MarkW
Post by MarkW » Sun Mar 24, 2019 7:53 pm
Greetings all
My speedo trip cable snapped some time ago, I tried to get the remains of the cable out so that I could replace it with the BMW one that fits but I can’t remove the remaining bit of cable. Not having a trip is becoming a real pain in the arse.
What good options for speedo replacement are out there? Ideally I would like it to fit nicely in the dash cut out. I don’t have big bucks for an all singing and dancing GPS one.
Cheers
Mark
MT604
BMW R1150GS
BMW R75/6
BMW R80 and Ural chair
Vtrsp1da
Re: Replacement speedo MT350
Post by Vtrsp1da » Sun Mar 24, 2019 8:08 pm
Which speedo do you have plastic or metal body?
sparky
Post by sparky » Sun Mar 24, 2019 9:34 pm
Did you remove the tiny pin hlding the cable in? I ground an old valve down very thin to punch it out, same with the adjuster knob. I made the cable from some old british speedo cable inner. This is thicker, I squared it and ground it down to fit.
Dave.
1994 MT350
1960 AJS model 20
1960 Matchless 650 CSR
1999 BMW F650ST
MarkW
Post by MarkW » Mon Mar 25, 2019 6:10 pm
Cheers for the responses gents. It is the plastic bodied type, I’ve been trying to remove the tiny pin but haven’t been able to get it to budge as of yet.
post images
MT604
BMW R1150GS
BMW R75/6
Vtrsp1da
Post by Vtrsp1da » Mon Mar 25, 2019 6:43 pm
I've had the same problem I managed to remove the role pin using a watch pin removal tool if you get stuck pop in the post and I'll have a go at getting it out.
Dave
MarkW
Post by MarkW » Mon Mar 25, 2019 7:37 pm
Cheers Dave. I’ve got a watch pin tool for a couple of quid on its way so will give that a go.
MT604
BMW R1150GS
BMW R75/6
Post by Minter » Tue Mar 26, 2019 7:08 am
MarkW wrote: ↑
Greetings all
Cheers
Mark
I have a prototype replacement Speedo that fits in the dash on a 350 probably do a 500 as well but I'm always busy with engines and now wiring looms to finish this little project off. If any one wants to pop in with their MT is useful with spanners etc and do the fettling I can then get the kit and instructions added to the webshop..
MarkW
Post by MarkW » Thu Mar 28, 2019 8:14 pm
I managed to finally get the pin out. Will try the remains of the broken cable tomorrow but shouldn’t be too difficult.
BMW F650 cable I think fits doesn’t it?
MT604
BMW R1150GS
BMW R75/6
Vtrsp1da
Post by Vtrsp1da » Thu Mar 28, 2019 8:37 pm
MarkW
Post by MarkW » Thu Mar 28, 2019 8:44 pm
The F650 unit looks very similar in appearance. Any one measured it up for size?
MT604
BMW R1150GS
BMW R75/6
Users browsing this forum: landy man and 0 guests
