Trip
Any MT parts
Sloppy Link
Trip
Post by Sloppy Link » Thu Jul 05, 2018 4:37 pm
Trip knob is missing to reset mileage, any easy fixes? Can't find the part in the workshop manual....
Matt
‘13 KTM Adventure 1190
‘03 BMW F650GS
‘85 Armstrong MT500
‘67 Norton P11
FordPrefect
Re: Trip
Post by FordPrefect » Thu Jul 05, 2018 8:56 pm
Your trip counter actually works? Thats a rare thing indeed! I'm sure I've seen replacement cables on either LMS or Sportax, knobs I'm not sure of. The oracal (aka Wirralman) will know more I'm certain.
1993 MT350 bought August 2017
Re: Trip
Post by Wirralman » Thu Jul 05, 2018 9:32 pm
Tripmeter failure is quite common although both of the MTs I had on the road worked fine. Waiting for years in storage, both within service but especially after disposal, has not helped
From a military point of view, just draw a new speedo from stores and dispose of the faulty part, the cheapest and easiest solution. Hence it doesn't surprise me that you can't find either a part number or indeed a part.
The tricky situation now is that supplies of speedos are drying up.
danswankie
Re: Trip
Post by danswankie » Thu Jul 05, 2018 10:37 pm
Il have a look tomorrow
Barrie
Re: Trip
Post by Barrie » Thu Jul 05, 2018 11:07 pm
I believe the agreed upon solution is to open a bic biro and use the open end of the inner ink sleeve to slide over the trip reset spindle, rotating it should reset trip. Unless I've tottaly made that up.
Jawa CZ 125
click here
Sloppy Link
Re: Trip
Post by Sloppy Link » Sat Jul 07, 2018 1:43 pm
Dans....Thank you
Barrie.....Neccessity is the mother of invention etc!
Wirral.....to general a search
All, what I want to to do is set the trip so I know roughly when to fill up (150 miles?), the other answer is to carry a 2l fuel bottle that becomes my reserve.
‘03 BMW F650GS
‘85 Armstrong MT500
‘67 Norton P11
Re: Trip
Post by Wirralman » Sat Jul 07, 2018 3:21 pm
With regard to range, it does vary by bike ,terrain, and riding style
I used to fill tank and reset trip After 110 miles i would fill up if i came across a fuel point When riding with others one time, I think I reached 128 miles before spluttering that was having switched to reserve a little earlier. I could probably found a little more if I tipped the bike over
I bought one MT350 and rode it home 300 miles, taking it easy 55 mph because I was unsure of the bike stopped after 110 miles and was surprised how little it needed So constant speed, not thrashing it unsurprisingly you use less fuel
A small 2 litre fuel can that slides into a pannier box is useful insurance, especially in remote areas
Sloppy Link
Re: Trip
Post by Sloppy Link » Sat Jul 07, 2018 3:51 pm
I suppose the answer is to fit a tap with a reserve setting and a main.....does such a thing exist for MT500?
‘03 BMW F650GS
‘85 Armstrong MT500
‘67 Norton P11
Re: Trip
Post by Wirralman » Sat Jul 07, 2018 4:14 pm
The reserve mechanism only works if the plastic tube that fits inside the tank is intact They often aren't😢
One member with a 500 engine fitted a new tap He said his 'reserve' was disappointly just a few miles
Fuel consumption is higher for the MT500 and riders often carry spare fuel
FordPrefect
Re: Trip
Post by FordPrefect » Sun Jul 08, 2018 8:35 am
It looks like the tube on my bike has gone as I found out last Thursday riding home when the engine abruptly stopped running at 50mph come down a lane near work. I pulled in, opened the filler cap and there wasn't a drop of fuel to be seen or smelled! I'd neglected to check the level that morning as I'd been in a rush, lucky for me I've got a knock-off rotopax 6L Jerry can on the bike at all times so I got home ok. I worked out my mileage, double checking against Google maps and it was just shy of 170 miles to a full tank.
