Riding by candlelight
Check here before posting your questions
A W Hopkins
Post by A W Hopkins » Fri Apr 01, 2016 7:33 pm
I dont know folks, this 12w low 12w high just does not do it for me. Can anyone tell me if the lamp (bulb) fitting on the headlight is the H4 fitting? If it is I have found a site doing them cheapish and its 40w low 45w high which will save me waiting at the side of the road for a car to go in front in lanes and people might stop thinking I am a pushbike and just pulling out.
cheers comrades, Uncle Hop :D Oh mot today bike starts 2nd kick ticks over great and all is well with the world (apart from the headlight)
Re: Riding by candlelight
Post by bth2bth2 » Fri Apr 01, 2016 8:15 pm
if its the 500 then look for a BA20D halogen lamp. you can get them in a higher wattage.
Post by hounddog » Fri Apr 01, 2016 8:57 pm
BA20D in mine is 35w/35w . a bit feeble and i need to eat a few carrots! But its just about useable . I have heard a few horror stories about higher wattage halogen bulbs being used and overheating the bulb holder and overloading the wiring so be careful if going more powerful than the standard bulb
A W Hopkins
Post by A W Hopkins » Sat Apr 02, 2016 12:43 am
cheers guys, i got a chinese headlamp that i might stick on my conker (jeff duke helmet for the young fkrs) to save overloading the electrics :D
Post by ZIP TIE » Sat Apr 02, 2016 2:25 am
eBay; hb12 halogen bulb and the the locking ring if you need it
Andi_Archer
Post by Andi_Archer » Sat Apr 02, 2016 12:58 pm
hounddog wrote: I have heard a few horror stories about higher wattage halogen bulbs being used and overheating the bulb holder and overloading the wiring so be careful if going more powerful than the standard bulb
On that note with a lager watage light you could install a relay set up to use the old switch gear but supply current straight from the battery on a newly installed cable which would also reduce the voltage drop inherant in the old system.
Its all fun and games till someone loses their keys
sparky
Post by sparky » Tue Apr 05, 2016 7:22 pm
I fitted the relay kit from Rex's Speedshop, then fitted an H4 halogen bulb by turning an alloy adaptor ring and removing the original bulb holder. The dip beam is now very good but the head beam is poor. From the front its very bright but its so scattered that its not much use. Maybe my DIY adaptor is the wrong thickness? I think I made it 6mm thick.
Dave.
1994 MT350
1960 AJS model 20
1960 Matchless 650 CSR
1999 BMW F650ST
1985 Honda XBR500
Andi_Archer
Post by Andi_Archer » Tue Apr 05, 2016 8:07 pm
Yep but Rex is no longer making the units after the last batch was run.As to your bulb its probably not in the focal point of the lens being further back than normal.
Post by ZIP TIE » Tue Apr 05, 2016 8:22 pm
Two relays, some wire, some crimp terminals and the bulb of your choice it really isn't rocket science DIY
sparky
Post by sparky » Tue Apr 05, 2016 9:13 pm
Yes, sorry I thought I'd read they were back in stock but I must have dreamt it. (Happens a lot, its an age thing!) I know its not focussed but I only guessed the thickness of the adapter and If I get that right the dip will probably then be no good. I'm happy to use the dip only, its pretty good and the head's a great daytime light! (really bright!)
I did my own upgrade on my AJS 500 twin with 2 Bosch car relays. It was cheap (free!) and worked really well, but seems a bit of a clumsy way compared to Rex's neat job. :D
Dave.
1994 MT350
1960 AJS model 20
1999 BMW F650ST
1985 Honda XBR500
