Gates Cam Belts. Suppliers.
joeg4rss
Post by joeg4rss » Fri Apr 29, 2016 8:06 am
HI,
Anyone have information on a Gates Cam Belts for the MT 350 ( NEW ).
Many thanks Joe.
Re: Gates Cam Belts. Suppliers.
Post by hounddog » Fri Apr 29, 2016 10:47 am
I have no knowledge of Gates and whether suitable or not .
The recommended part for the Rotax is the Dayco belt as sold by the usual suppliers .(Sportax, Force , LMS) It is designed to stand up to the stresses of a motorcycle engine .
personally speaking I would not use anything else.
The ones definitely not to fit on bikes are machine belts which are really just designed to run at a steady speed under no sudden loads . some of these are very cheap and may let you down very quickly-.
Harley Davidson MT350e
Armstrong MT500e
Armstrong MT500 -current project
Post by Mr Shiney » Fri Apr 29, 2016 11:15 am
hounddog wrote:I have no knowledge of Gates and whether suitable or not .
What Ian says!! We had a problem as a group a couple of years ago with not using the correct belt with breakdowns at roadside etc.
Post by appyarry » Fri Apr 29, 2016 11:58 am
hounddog wrote:The ones definitely not to fit on bikes are machine belts which are really just designed to run at a steady speed under no sudden loads . some of these are very cheap and may let you down very quickly-.
I bought one from a supplier (No longer in business) that was advertised as for the MT350 and it lasted less than a fortnight :-( I never bought anything from that person again.
Caveat emptor :-)
joeg4rss
Post by joeg4rss » Fri Apr 29, 2016 8:00 pm
HI,
Thank you all your input and help regards the cam belt.
I will be fitting the correct Dayco belt.
Regards,
Joeg4rss.
