Head Gasket
namtip
Re: Head Gasket
Post by namtip » Sun Feb 22, 2015 3:31 pm
A list of suppliers is given in the FAQ section at the very top of the forum page. Gary of Sportax racing will be able to sort you out:
http://sportaxracing.co.uk/
He's also known as "Minter" on this forum.
Re: Head Gasket
Post by ZIP TIE » Sun Feb 22, 2015 3:42 pm
350 doesn't have a head gasket just o'rings and a base gasket
namtip
Re: Head Gasket
Post by namtip » Sun Feb 22, 2015 3:47 pm
Problem solved then Daniel!
gegdonnell
Re: Head Gasket
Post by gegdonnell » Sun Feb 22, 2015 3:50 pm
Good one Colin
Re: Head Gasket
Post by ZIP TIE » Sun Feb 22, 2015 4:06 pm
Check the ring end gap but be careful they are very brittle (especially the oil ring) and quite expensive, then check bore wear valve seals and guides.
Also did you start it on fresh petrol or what had bee left in the tank?
Re: Head Gasket
Post by Minter » Sun Feb 22, 2015 6:59 pm
Sounds like a nice little project Daniel..
You'll probably need one of these kits.. comes with new valve stem seals too..
http://sportaxracing.co.uk/shop/kits/to ... t-999-016/" onclick="window.open(this.href);return false;
I also have piston rings in stock too if you still need them..
http://sportaxracing.co.uk/shop/cranksh ... g-215-400/" onclick="window.open(this.href);return false;
top and midle rings in the same section..
Hope that helps and good luck..
