alternative chain adjuster
Aleman
Post by Aleman » Wed Sep 17, 2014 6:27 am
Hi all, I did the search for above but didn't find any pics.
Does anyone use other than the snails to tension their chains?
This chain not as good as original but also plenty adjustment to tension but snails at max.
Ideas please would be appreciated.
Many thanks.
Keith.
rustybike
Re: alternative chain adjuster
Post by rustybike » Wed Sep 17, 2014 6:48 am
You may need to remove a link or 2. I think the chain should be 102 links long but i am sure some one will correct me if I am wrong. :D
Post by Minter » Wed Sep 17, 2014 11:14 am
rustybike wrote:You may need to remove a link or 2. I think the chain should be 102 links long but i am sure some one will correct me if I am wrong. :D
Armstrong chains are 104 links, maybe you have one of those fitted...
Aleman
Post by Aleman » Thu Sep 18, 2014 11:42 am
Thanks chaps.
Looks like a job for the weekend.
Cheers.
Aleman
Post by Aleman » Fri Sep 26, 2014 8:58 pm
It's a new chain and sprocket set plus fish drive. Then should be sorted.
Post by arceye » Fri Sep 26, 2014 9:50 pm
Aleman wrote:It's a new chain and sprocket set plus fish drive. Then should be sorted.
Don't think I have seen a fish drive before. :shock:
Greybeard
Post by Greybeard » Sat Sep 27, 2014 12:34 am
Its for the underwater sections Phil :lol:
Daj
Post by Daj » Sat Sep 27, 2014 6:54 am
If you are using a fish drive make sure you put it in the right plaice.
Daj
Sent from my KFTT using Tapatalk
MT500e
Post by appyarry » Sat Sep 27, 2014 5:22 pm
What is a "Fish Drive"?
Ta,
Post by ZIP TIE » Sat Sep 27, 2014 5:55 pm
appyarry wrote:What is a "Fish Drive"?
Ta,
