MT350 starter motor
Any MT parts
Ricky
MT350 starter motor
Post by Ricky » Mon Sep 09, 2019 2:40 pm
I may need a starter motor if taking mine off and reconditioning it doesnt work.
Does anyone have one at a reasonable price ?
regards
Ricky
Re: MT350 starter motor
Post by Wirralman » Mon Sep 09, 2019 3:01 pm
This would be quite a rare failure
Try the things I've mentioned in your other thread You could spend a lot of money but still not sort your problem
Even if your starter is not working with all electrical connections good, changing the brushes would be my first step before renewing the whole motor
Ricky
Post by Ricky » Tue Sep 10, 2019 4:22 pm
Thanks for that,
Any idea where I can source a new set of brushes ?
Kind regards
Ricky
Post by Wirralman » Tue Sep 10, 2019 5:13 pm
See forum Links Commercial
Ricky
Post by Ricky » Wed Sep 11, 2019 5:26 pm
Thanks for that ...
Can someone tell me the best way to remove the starter motor please ...
Kind regards
Ricky
Post by twmtomos1 » Wed Sep 11, 2019 5:37 pm
exhaust will have to be removed and the last one i did the motor had coroded in the cassing and the end of the motor broke off and stayed in the cassing,so i would start soaking every yhing in WD40 including the exhaust studs not a easy job if nothings been removed for a while
Ricky
Post by Ricky » Wed Sep 25, 2019 2:43 pm
motor removed cleaned and re greased, re assembled, bike started first time.
Thanks for all the assistance .
