MT 350 Bottom end
Any MT parts
Simonrd
MT 350 Bottom end
Post by Simonrd » Fri May 31, 2019 7:15 pm
Looking for a bottom end or just the idler gear for a 350 for parts if anyone has one for sale for an ongoing project.
Re: MT 350 Bottom end
Post by Minter » Fri May 31, 2019 7:50 pm
There are a few idler gears in the motor can you quote a part number? We have all parts in stock if you need a specific part..
Simonrd
Post by Simonrd » Fri May 31, 2019 8:01 pm
I think it’s no21 engages to the starter motor.
They are pretty pricey new so was looking at a used one. Looks like red rose are selling a couple but they want £140. It’s for a motor I’m going to drop off with you to rebuild but I wanted to get it complete before dropping it off. My only issue is that it’s a Aprilla motor, are these gears different sizes?
Post by Minter » Fri May 31, 2019 8:38 pm
234 053.. 81&15 teeth. we have new and used. 88 for used 190 for new. Red Rose probably used too. This gear is the same on an Aprilia motor..
Simonrd
Post by Simonrd » Fri May 31, 2019 8:49 pm
Great, in that case I’ll drop the engine off. When’s good for you?
Post by Minter » Sat Jun 01, 2019 7:01 pm
No probs, You can drop it off any time you like! I'm booked up until week comencing 24th June. I should be able to sort it out then..
Hope that helps..
