New member
Forum rules
Persevere - we're worth it!
GeeGeeK
New member
Post by GeeGeeK » Sun Oct 20, 2019 6:45 pm
Just bought an MT350, a bit different from my current road bike but I've owned stranger things in the past! Having a bit of a fight with the clutch drag but assured it will improve or I'll get used to it. Gearbox is fine when warm but trying to engage neutral at a standstill is near impossible, any advice on this very welcome.
Nick
Re: New member
Post by Wirralman » Sun Oct 20, 2019 7:54 pm
Welcome to the forum
Check out the start of the forum General section, an early post is Teeshirts- you have numbers 8 and 9
Firstly, make sure that your clutch is adjusted correctly, if you need a clutch adjusting tool drop me a PM (private message)
Secondly, try selecting neutral whilst your bike is still rolling a little
If you have no joy with these, you will probably solve your problem by stripping the clutch, cleaning plates and checking thickness against the spec in the manual , see forum Manuals section, renewing springs and plates if necessary. See Joth's excellent tutorial on refurbing the clutch. One special tool required - clutch holding tool
If you don't want to do the clutch yourself, contact Sportax, they are the MT engine specialists. There may be some MT owners near to Fordingsbridge who are able to help
Re: New member
Post by Derrick » Mon Oct 21, 2019 3:25 pm
Welcome.
Good advice from Wirralman, I would recommend at least re-adjusting the clutch.
Mine was starting to be difficult to select neutral when stationary but re-did the clutch setting and now goes into neutral without a problem. Many owners carry a spare clutch cable and timing belt as these are both very easy to change at the side of the road and probably the two items that are most likely to break when riding.
If you want to get to get to know a bit more about the bike, stripping and checking the clutch and timing belt are good tasks to start with.
1997 HD MT350
2002 Honda Pan European 1300
2015 Honda CB500F
12royal
Re: New member
Post by 12royal » Mon Oct 21, 2019 6:24 pm
A warm welcome to the forum. If you need and advice bring yourself to the next big meet with an empty stomach and be prepared for some adult fun 😱
Regards, Alan
Re: New member
Post by Minter » Tue Oct 22, 2019 5:48 pm
Welcome to the forum Nick,
Not an uncommon problem that you have, easily fixable by refacing the clutch basket and checking the clutch pack dimensions.
We offer this as a while you wait service at Sportax now..
Sportax Racing
01952 850802
P.I.STAKER
Re: New member
Post by P.I.STAKER » Sat Oct 26, 2019 9:17 am
Hi Nick and welcome aboard
https://sites.google.com/site/gvsparts/
ARMSTRONG MT500 1984
BMW R1100S
