20 gallon paraffin washer
Re: 20 gallon paraffin washer
Post by Mr Shiney » Tue Oct 08, 2013 9:05 pm
Don't you have a paraffin gun? I have one that runs on the compressor. You stick a litre of paraffin or other degreaser in and blast away. I use a big plastic tub to stand whatever I am blasting in so I can recycle the cleaner.
vic
Post by vic » Tue Oct 08, 2013 11:45 pm
Hi Mr Shiney
Yes I used the paraffin gun and got good results with it. I am looking at a system I can just pick up the gun and off I go. The paraffin will be picked up from the return tank that i will filter at the bottom.
I know it sounds over the top just to wash parts, but when I am using it around 30 times over the weekend and at night after work it will be a handy bit of kit.
Vic
Post by Mr Shiney » Wed Oct 09, 2013 8:48 am
You are probably over engineering the solution. The tub I use collects the paraffin/Jizer under a mesh and I just pour it back in the pot. If you wanted to get clever you could remove the pot and connect a hose to the pick up and run it direct from the sump.
Post by Derrick » Wed Oct 09, 2013 12:32 pm
vic wrote:Yes I used the paraffin gun and got good results with it
Are you talking about somethign like this?
http://www.machinemart.co.uk/shop/produ ... -spray-gun" onclick="window.open(this.href);return false;
Can these be used with other engine cleaners? I normally apply with an old paintbrush, but spraying on solvent would get into those small corners, particularly on the engine.
1997 HD MT350
2002 Honda Pan European 1300
2015 Honda CB500F
Post by Mr Shiney » Wed Oct 09, 2013 1:36 pm
Yes, I use the draper version of it but the same thing. I use Jizer with it or if really greasy use Avgas first then Jizer. By putting it in a big plastic bin I can re use it many times over.
