Parts Washer & Fluid
Post by Mr Shiney » Mon Dec 24, 2012 10:55 am
I am in the market for a parts washer and have been contemplating the following:
http://www.machinemart.co.uk/shop/produ ... rts+washer" onclick="window.open(this.href);return false;
I am also looking for a suitable washing fluid. I really want to reduce the chemicals that I buy and have to store so was thinking of using Swarfega Jizer both for general degreasing and in the parts washer. Machinemart tell me this is fine.
I am just wondering about others experience of this as a solution?
The main stuff is things like brakes and engine parts.
Re: Parts Washer & Fluid
Post by Minter » Mon Dec 24, 2012 11:01 am
Mr Shiney wrote:I am in the market for a parts washer and have been contemplating the following:
Morning Steve, same as mine had it about 18 years.. Ive used Kero A or B in mine all that time! But only as it was free! A good bit of kit for any wksp..
philgunn
Post by philgunn » Mon Dec 24, 2012 11:09 am
have a look here at the post from VIC
http://forum.mtridersclub.co.uk/viewtop ... 71&t=11613" onclick="window.open(this.href);return false;
pg
MT500
MT350/e
CVT560
BSA B40
BSA M20 (Bits Required)
Sanglas 400 Militario
Sanglas 400 Electrico
CanAm250 Bombardier... i better stop there
Post by TDIPower » Mon Dec 24, 2012 11:52 am
I have the same one. I got the machinemart fluid that is let down with water. this was crap. it more smeared the crap about than cleaned. So i got some of the other stuff machinmart do last time which was great.
My pump has been on the blink for ages so when I finaly move ill get that up and running again. Wish Id got the larger one though.
One tip, get a length of rubber hose and a parts wash brush. connect the hose to the outlet of the pump and pump the fluid through the brush.
Post by Bunker » Mon Dec 24, 2012 12:45 pm
Ill be installing one in the new year too. Use your central heating oil Steve, 28sec Kerosene.
Thumper
Post by Thumper » Mon Dec 24, 2012 12:46 pm
Ditto re the machine. For fluid I use paraffin mixed 70/30 with water
The advantage of this is that crud mixes with the water and can be drained off leaving clean paraffin behind. Simples.
I also add a squirt of diesel bio-inhibitor to stop mould forming
Post by Mr Shiney » Mon Dec 24, 2012 1:04 pm
Now thats not a bad idea at all lads!! Heating oil is easy to get at. I could also use the waste Jet A1 from work.
Does the parts washer itself I am looking at cut the mustard?
Murdock
Post by Murdock » Mon Dec 24, 2012 2:51 pm
I got a parts washer from Machine mart. I used the fluid they supplied, but the damned stuff dissolved the pumps plastic case :?
Can-am Bombardier 250 [McQueen]
Honda Valkyrie 1500 [Star ship cruiser]
VW T4 Surf bus [but dont surf]
If you have to ask "WHY" then you wont understand!!!
MT Pocket
Post by MT Pocket » Mon Dec 24, 2012 9:21 pm
Avtur works well for cleaning and hasn't degraded pump or even the plastic cover on the switch.
It should also be easy for you to get hold of.
MT 604 (Piggles- baby hog with wiings) bits of allsorts, CCM, WP, Brembo, hagon
vic
Post by vic » Mon Dec 24, 2012 10:22 pm
Hi All
The one I bought from JTF is the same as the one from Clarks. Same tank, switch, pump, and the lid got a automatic slam down device built in if there is a fire in the tank.
I paid Ă‚ÂŁ19.99 + vat last time I looked they were Ă‚ÂŁ24.99 + vat
I am using some water based cleaner I got from work which is not bad, when I get chance might change to paraffin
I am using them tooth brush size nylon and copper wire brushes to scrub with.
Vic
