Suitable substitute for loctight 221?
MarkW
Post by MarkW » Tue Nov 05, 2013 12:44 pm
I need some loctite for when I replace top and bottom pulley on my 350. Local shop only sells loctite 221 in large quantities though, is a substitute available? Would 222 do the job?
Cheers
MT604
BMW R1150GS
BMW R75/6
BMW R80 and Ural chair
Re: Suitable substitute for loctight 221?
Post by appyarry » Tue Nov 05, 2013 1:02 pm
222 would do, there are many other thread locking makers as well as Loctite, all of which do a comparison list so you can see which one of their products is the same spec as the Loctite one. So you should be able to buy a 221 equivalent if you felt the need.
Ta,
Post by ellrider » Tue Nov 05, 2013 2:43 pm
Loctite and their numbers can be confusing. :?
Unless it is for a specialised job there are basically three types, four if you count the pre assembled penetrating one(green) and the liquid is colour coded.
1. Low strength - purple, which is usually used on smaller fasteners.
2. Medium strength - blue, which is the one we would be using for our fasteners, can be undone with hand tools.
3. High strength - red, which is usually used on larger stuff and/or fasteners that are mainly permanent.
