Undersealing vehicles
I am after some advice or experiences with Undersealing or proofing the underside of vehicles.
I have in the past used old oil/grease mixes, waxoil Ect.
I have to seal the bottom of two classic cars, this will not be a back to metal job. I need to seal over the existing paint/Undersealing and rust. Obviously loose rust and edges will be removed as will flaking patches of previous coatings.
I don't want to use old oil, and would like a black rather than clear finish. While I am sceptical about rust stoping addatives and the like of some of the products available I am willing to give things a try.
Any suggestions?
Any suggestions?
Re: Undersealing vehicles
This company is currently Rustproofing a 30 year old Vehicle for me. There is a lot of useful info on their website regarding treating/protecting vehicles.
http://www.rust.co.uk/" onclick="window.open(this.href);return false;
the mod used to use a hard setting underseal on the landrovers, the problem was if it cracked water would get in and let the steel rot under the underseal.
I used to use schutz but last lot I used on the landy was the Hammerite/waxoil/schutz http://www.hammerite-automotive.com/underbody.htm" onclick="window.open(this.href);return false; this was applied 9yrs ago to a rear 1/4 chassis section, never washed since and there are 1 or 2 spots which are starting to show the need for attention. not holes in the metal, just where the coating has been damaged exposing small areas.
Thanks for all the info so far, much appreciated.
Shiney...have you used the 3m product, if so how hard did it set?
Pete, yes I have been looking at that.
Problem with waxoil and bitumen based products is as you say the cracking and water ingress.
I have used ankorwax on original paint finishes in the past but don't feel it is quite up to use as a underbody sealer.
I used the 3m on the Landy. It sets hard but not rock hard. Has withstood heavy off road and quarry use.
Hi .....I've always used Waxoyl on my 1988 Citroen 2CV .....it has preserved the car reasonably well over the last 25 years [needing only a minimal amount of welding ....and 2CV's are renowned for rusting].
However ....the word in the 2CV OC {2CVGB} at the mo seems to be Bilt Hamber .... http://www.bilthamber.com/" onclick="window.open(this.href);return false;
....I aint tried it myself ....so I cant personally endorse it.
hth
ride safe
T.
hth
ride safe
T.
I use a 50/50 mix of black waxoyl and waste engine oil. Applied with a Shultz gun. Gets in to all the corners ( where rust always seems to start ) and never really sets too hard. I've found this slows transit rust down so you can hardly see it spreading daily!!!!
But I've got a Transporter!Jacko wrote:I've found this slows transit rust down so you can hardly see it spreading daily!!!!
nothing slows transit rust downellrider wrote:But I've got a Transporter!Jacko wrote:I've found this slows transit rust down so you can hardly see it spreading daily!!!!
