Workshop takes a delivery...
Re: Workshop takes a delivery...
Post by Bunker » Sat Oct 20, 2012 10:49 pm
we are trying to organise some training, either alex or myself, by the way, i have a very good training dvd, i will send you a copy simon.
Sounds great thanks!
Fergie
Post by Fergie » Fri Nov 30, 2012 8:21 pm
P.I.STAKER wrote:we are trying to organise some training, either alex or myself, by the way, i have a very good training dvd, i will send you a copy simon.
regards
george
Hi George,
I've also recently acquired a Harrison lathe (ex school) that I've converted to single phase using an inverter - I'm still trying to learn how to use it, so would appreciate a copy of your training DVD if you can manage an extra copy. I'll pm you.
Thanks,
John
P.I.STAKER
Post by P.I.STAKER » Fri Nov 30, 2012 9:45 pm
hi,
no problem, will sort within the next couple of weeks.
great addition to your workshop.
when you get a moment, put a couple of pictures up.
regards
george
ARMSTRONG MT500 1984
BMW R1100S
Fergie
Post by Fergie » Mon Dec 03, 2012 4:49 pm
Image Thanks George,
I've attached a photo of the Harrison lathe.
It's an ex-school lathe, and I removed all the original 3 phase wiring etc from the control box & fitted a variable frequency inverter with an external speed control with reverse & jog. It all works very well, I'm just starting to get the hang of using it.
John
Fergie
Post by Fergie » Sat Dec 08, 2012 8:36 pm
P.I.STAKER wrote:hi,
regards
george
Thanks George,
the DVD arrived today & is much appreciated.
Good basic training which shows what can be done on a miniature Chinese lathe - I was impressed.
John
Rudiemoto
Post by Rudiemoto » Sun Dec 09, 2012 3:53 am
you need this type of kit to run an mt
:shock:
Murdock
Post by Murdock » Sun Dec 09, 2012 12:02 pm
Rudiemoto wrote:you need this type of kit to run an mt
:shock:
Yes :!: And some owners carry it all with them in a ruck sack...Just in case :lol: :lol:
Can-am Bombardier 250 [McQueen]
Honda Valkyrie 1500 [Star ship cruiser]
VW T4 Surf bus [but dont surf]
If you have to ask "WHY" then you wont understand!!!
Post by appyarry » Sun Feb 24, 2013 8:31 am
Bunker wrote:'VARIABLE FREQUENCY DRIVE INVERTER'
Does the VFDI work well? Do you use the original 3 phase motor?
Thanks,
Jealous from Lyminge :mrgreen:
P.I.STAKER
Post by P.I.STAKER » Sun Feb 24, 2013 11:49 am
hi,
on my lathe, i run a 3 phase motor, through an inverter, the inverter is 1 x phase in and 3 phase out. the variable speed makes using the lathe very user friendly, no swapping gears or belts like the good old days. makes the control exceptionally easy. always using different speeds for different materials and operations.
hope this helps
regards
george
BMW R1100S
Fergie
Post by Fergie » Mon Feb 25, 2013 7:47 pm
Thanks,
Hi,
the original motor was 415volt only, but I managed to pick up a virtually new (still boxed) dual voltage 2HP motor from Gumtree, which fitted perfectly. I wired it for 240Volt 3 Phase, and the VFD works perfectly.
Since then I've acquired a Myford S7 from a deceased sale, and although it had a single phase motor the first thing I've done is convert it to 3 Phase with a VFD. I'm still restoring the Myford, but wouldn't consider not having variable speed. It transforms the lathe - especially compared to changing belt drives!
I'm not sure I need two lathes, but then I don't actually need eight bikes either, and they're different from each other...
John
