Search function problem.
As it says on the tin
Barrie
Post by Barrie » Tue Dec 26, 2017 7:02 pm
Hi guys.
Merry Christmas to you all.
Just wondering if there is anything that can be done about the search function. I can't seem to search for particular things because they are too common words.
Including "can am"
Jawa CZ 125
click here
Re: Search function problem.
Post by Wirralman » Tue Dec 26, 2017 7:13 pm
Exactly what are you looking for ?
If it's a colour MT500 wiring diagram , go to
Board Index
Technical
Manuals & Papers
MT & Rotax
MT500 Wiring Diagram
- go through results and you will find a post by Joth Hill 17 Jan 2015 with a direct link
Post by Derrick » Wed Dec 27, 2017 7:54 pm
I just tried Canam and got 260 results, so I assume there is a value at which it's too many for the search to cope with. Bunker may be able to say what the limit is. Can-Am gave too many.
Have a look at the search settings, you may need to refine the way it works (I hope you see a cog by the search, if it's not just an admin function)
1997 HD MT350
2002 Honda Pan European 1300
2015 Honda CB500F
Post by Wirralman » Wed Dec 27, 2017 9:47 pm
Derrick wrote: ↑
If you look at the bottom of the Search box , it is set to 300 If you set it higher, you would potentially get so many hits and if the forum was busy ! could slow the response time for everyone or even crash the forum altogether
I have searched many many times over the years and have had to think Can I ask this question in a different way ? Usually it only needs a little thought
As Derrick has pointed out canam works but
'can am' doesn't because there would be thousands of hits an 'can' ( searches must be 3 characters hence 'am' would be ignored)
Barrie
Post by Barrie » Sat Dec 30, 2017 9:00 pm
Wirralman wrote: ↑
Derrick wrote: ↑
Yep understand that. If it was google you could put "can am bombardier" with the " marks and it would only search for the words can am bombardier together, not seperately - greatly reducing hits. Is this possible on our forum?
Jawa CZ 125
click here
Post by Wirralman » Sat Dec 30, 2017 9:56 pm
Barrie wrote: ↑
No and yes. No you can't do what you want to do the way you want to do it Yes you can do it by using a Search within a Search Whilst not elegant from a systems point of view, this clunky approach should narrow down the hits you get
